Results 1 to 6 of 6
- 05-22-2010, 03:32 PM
Thread Author #1
Launcher Pro...Questions! Please help!
Hey everyone!
I recently downloaded Launcher Pro and I can easiy see it taking the place os Sense UI n my Incredible. I was wondering if anyone knew how to get the widgets from sense to show up over in the menu for Launcher Pro. The ones I'm looking for in particular is the big flip clock and the power control widget. (the favorites and bookmarks widget would be nice too but not necessary...
Thanks in advance! I'm new to Android and I appreciate your help!!! - 05-22-2010, 05:41 PM #2
- 05-31-2010, 05:45 PM #3
- 05-31-2010, 06:50 PM #4
yep. when you tap on the message widget the first time, it will ask you which messaging app you want to use as your default. if your stock messenger is already set, just go into the manage apps area and clear it as the default. the new update to launcherpro also allows you to put whatever app shortcuts you want in the dock; just long press a dock shortcut to pick which app you want
- 06-01-2010, 04:36 PM #5
- 06-01-2010, 04:46 PM #6
Hitt, terpitude is correct. If you are not getting that option, I may suggest you uninstall and re-install again.
Reply
