Results 1 to 9 of 9
    Default Error msg "Problem Loading Widgets" with various Launchers???
    Searched online and found quite a few threads about this, however no real answers as to the cause/fix.
    I have an AT&T GS2, no issues like this on TouchWhiz, but when using Go Launcher Ex, ADW etc... at least once or twice a day my widgets go blank and say "Problem Loading Widgets". Sometimes they come back after like 10-15 minutes other times not, and you have to hard reset to get them back, tried reinstalling and same issue. Sucks, b/c I especially like Go Launcher Ex. Obviously not the only one that has this issue as searching online finds a bunch of threads about it, but like I said no real fixes.
    here's a snapshot example:
    and the toggles widget does it also though it's shown here fine:
  2. #2
    Default Re: Error msg "Problem Loading Widgets" with various Launchers???
    Does it happen with widgets from different apps? Only widget of a certain app (or the launcher's itself)?
  3. #3
    theexile1's Avatar
    Posts
    ROM
    MIUI Alpha V4
    dont put wigets on your sd card or sd ext. or your gona have to redo them every time you boot
  4. #4
    Default
    Widgets or apps that requires password must be installed to the internal storage.
    It can not be move to the FAT32 portion of the sf card.
    If the rom support app2ext that work fine.
    Sent from my Transformer TF101 using Tapatalk
    Quote Originally Posted by kamtsa View Post
    Yeh, like that 3rd pic is the toggle widget from Go Launcher itself and it did the same thing. So far only happened once today, and it popped back up after pressing power button, and then unlocking.
    Quote Originally Posted by theexile1 View Post
    I know that already, but don't have sd card anyway, this is on internal storage.
    Quote Originally Posted by baseballfanz View Post
    Not sure what you mean, I don't have a password for any widget? But either way their all stored internally, since I haven't gotten an sd card for it
  6. #6
    Try uninstalling the widgets that you are having problem with and reinstall them. Also, do the same to the Home Launchers, sometimes a poor installation can cause the problem.
    Default
    Quote Originally Posted by dfine1966 View Post
    Tried that already
  8. Thread Author  Thread Author    #8
    Hasn't done it so far today, and only once yesterday... we shall see
  9. #9
    Quote Originally Posted by surf1 View Post
    Maybe I miss typed. I'm trying to say apps with widget OR apps with password.
    Not widget with password. LOL.
    but since you have apps install internally disregard my post.
