Results 1 to 8 of 8
    D16RR's Avatar
    Posts
    Global Posts
    294 Global Posts
    Default Print directly to Bluetooth printer
    What is the best app for printing PDF and Office files to a mobile bluetooth printer directly from an android phone with no other devices or technology present (i.e. wifi, cloud, etc)?
    EDIT: It looks like Printershare will get it done, however it appears some additional software is required to render the office and PDF files. Any recommendations in that area?
  2. #2
    Default
    Quick office or documents to go should do the job.
    from Evo4GLTE on Android Central
  3. #3
    Xopher's Avatar
    Posts
    Global Posts
    4,723 Global Posts
    ROM
    All Stock
    Default Re: Print directly to Bluetooth printer
    PrinterShare works well for me. If the printer is wifi-enabled, or bluetooth, then the only thing that PrinterShare needs is the printer driver (which it will add to the Android device), and maybe the rendering engine (also on the device). Once those two parts are installed, it works just fine.
    Depending on the printer, they may have an app. I have an Epson printer. There is an app out for it (Epson iPrint) that works directly with that printer. The latest update added document support. Plus it will print borderless photos.
    RuneCryption - Unique memory puzzle game for Android. ( Google Play - Amazon Appstore )
    D16RR's Avatar
    Posts
    Global Posts
    294 Global Posts
    I just need to print PDFs and DOCs on the road to my HP 470 bluetooth printer. If I'm near a wifi printer, I'm on a desktop.
  5. #5
    Default
    If you use one of the two early suggestions I made. You would then have to convert the file using the app and then print.
  6. #6
    You can print to a bluetooth printer using android os. Check below link
    Android bluetooth printer application | Over Globe
  7. #7
    what is the easiest way ?
  8. #8
    I need similar help, I can't print from my MZ 420.
    Please can some one help me how to go about it?
