Results 1 to 11 of 11
- 06-25-2010, 08:32 AM
Thread Author #1
SMS Auto Response Based on Speed Traveling
So here's an App that I personally would love to see created. If I had any sort of Dev skills I would create it myself. My wife gives me grief if I don't respond to her TXTs/Answer the phone right away. The problem, is that I refuse to do either while I'm driving.
My guess is that I'm not alone in not wanting to be one of the many distracted drivers out there, and I bet there are others that would like an app that does this:
Idea for App
Use GPS to determine your speed.
If you are traveling at a speed greater than 10MPH (User defined) then send calls directly to Voice mail and setup an SMS auto response (user defined.)
Something like, "<auto response>I'm currently driving. I'll reply to your message when I reach my destination."
Once a phone reaches a speed greater than 10mph (user defined) a button is placed on the lock screen that you can hit once you have actually reached your destination/you want to disable the auto response. Also, you could auto disable after X minutes (user defined) below 10mph (user defined).
If done well, I'd totally buy an app that does this. - 06-25-2010, 08:51 AM #2
I had a similar idea but mine was an app you'd have to open before driving and close after. Hadn't even thought of using the GPS to automatically do it. Therefore, your idea wins...
Thanked by: - 06-25-2010, 08:51 AM
Thread Author #3
Speed
I just realized that this sounds allot like Speed. If this app is created, please don't try to replicate the movie.
On a side note, perhaps another feature of an app like this could be to setup alarms if you exceed certain speeds or if you fall below certain speeds. Maybe this could help sleepy/distracted drivers. Maybe the app could ping a database of posted speed limits somewhere and notify the driver if they are exceeding or are under the posted speed limit. I don't know, maybe that should be an app all on it's own. Feature bloat is always a risk. Oh well, these apps probably already exist and I've just not found them - 06-25-2010, 08:53 AM
Thread Author #4
- 06-25-2010, 09:04 AM #5
Not a bad idea. I prefer the social solution myself though.
- 06-25-2010, 10:43 AM
Thread Author #6
- 06-25-2010, 11:29 AM #7Thanked by:
- 06-25-2010, 12:28 PM #8Thanked by:
- 06-25-2010, 03:36 PM
Thread Author #9
- 06-25-2010, 03:37 PM
Thread Author #10
- 06-28-2010, 11:53 AM
Thread Author #11
Over the weekend I tried both the "Driving Text Answering Machine" and "Otter." Unfortunately, I just discovered another need for these app, and that would be Google Voice support. Without it, they are both useless to me since I use GV for 100% of my txt and voice service.
Reply
