Results 1 to 2 of 2
    Default Audiobook purchase on iTunes--will it work on Android?
    I don't have much experience with the iTune store but have it because my daughter has an iPod Touch. I'm looking to purchase some audiobooks and don't want to do a subscription like Audible.com offers. A friend of mine suggested buying from the iTune store, but she didn't know if I could download the book to my computer as an audiofile than upload it to my phone (samsung galaxy 3). Does anyone know if I can do that?
    Thanks for your help in advance!
  2. #2
    TheAutoMomma's Avatar
    Posts
    ROM
    CM9/Countershrike v. 2.3A
    Default Re: Audiobook purchase on iTunes--will it work on Android?
    Well, iTunes is pretty proprietary as far as using their files on other devices. However, I am fairly sure that you can do the ol' burn it to a cd then load it to the computer trick. Someone may have an easier way, but I've always had luck just downloading from iTunes, burning to disc, then reloading it in to whatever file you use for your phone's audio.
    HTH! There are always ways around Apple's proprietary rules. :-)
    Sent from my Rezound using Android Central Forums
    Thanked by:
  1. Replies: 0
    Last Post: 06-17-2012, 11:08 PM
  2. will it work on at&t?
    By tcfreak20 in forum Other Sony Android Phones
    Last Post: 03-01-2012, 12:24 PM
  3. Iphone on verizon, will it over shadow android?
    By RaHarmakis in forum General News & Discussion
    Last Post: 01-11-2011, 04:36 PM
  4. Will it work on Telus?
    By sookster54 in forum myTouch 3G Slide
    Last Post: 07-31-2010, 08:25 AM
  5. Replies: 17
    Last Post: 05-23-2010, 03:48 AM
