Results 1 to 8 of 8
    Default ColorNotes password problem..HELP!
    I recently switched phones. And am unable to restore my backed up notes to my new phone. I have the .dat and .idx files in the /data/colornote/backup directory, but ColorNotes asks for my password (presumably the password I set on my old phone) which I don't remember anymore. How can I restore these notes if I don't have the right password?
    Is there away to recover these Notes?
    Thanks,
    Joe
  2. Thread Author  Thread Author    #2
  3. #3
    levelm's Avatar
    Posts
    Global Posts
    253 Global Posts
    Default
    Try default password '0000' (numbers)
    If that doesn't work:
    Q: I forgot my password, how can I change it?
    A: Menu -> Settings -> Master Password -> Menu Button-> Clear Password.
    !! You will lose current locked notes when you clear password.
  4. #4
    Johnly's Avatar
    Posts
    ROM
    AOSP, & stock.
    Default
    Quote Originally Posted by levelm View Post
    LOL, you must "know" the password to clear the password.
    For those using this app, don't forget thy pass-code
    Default
    0000 doesn't work for Notes backed up previously on a different phone (and with an unknown password).
    There has to be a way to get those backup notes restored.
  6. #6
    Talking Re: ColorNotes password problem..HELP!
    Bump
    Quote Originally Posted by jhilario72 View Post
  7. #7
    Default Re: ColorNotes password problem..HELP!
    It's possible to reset password and still keep the locked data.
    First back u to sd card in colournote menu- settings-back upthe in settings clear master password
    Then go to back up choose the back up and restore
    The locked data will still be locked but when u open it it will ask you for a new password
    Hope it helps
    Thanked by:
  8. #8
    That doesn't work when I click on backup data it asks for master password
