Results 1 to 11 of 11
Like Tree2Likes
  • 1 Post By ioo
  • 1 Post By needsleep
    worknman's Avatar
    Posts
    Global Posts
    49 Global Posts
    Default What is the closest thing Android has to iOS's 'do not disturb' mode?
    I don't sleep with my phone (Gnex running Jellybean 4.1) in my bedroom because I have about 5 different apps (including Google Voice) that are constantly chirping with notifications. However, this is a problem when somebody needs to get a hold of me before I wake up.
    So I'm looking for an app or something that will let me set all notifications to silent, and send all but a couple of people to voicemail. I've seen a few apps in the Play store that will let you do this on a schedule, but I don't have a set work schedule, so I need to be able to do this manually.
  2. #2
    ioo
    ioo is offline
    ioo's Avatar
    Posts
    ROM
    Stock
    Default Re: What is the closest thing Android has to iOS's 'do not disturb' mode?
    Tasker can do this. It has a steep learning curve, but is one of the most powerful tools you can get. You can create widget buttons on your desktop to go into and out of your "do not disturb" mode.
    Bobman likes this.
  3. #3
    I have same desire, I wish to silent notifications at night, but still allow phone calls. I don't care about emails, calendar, updates when I am trying to sleep, however I do need to be able to receive emergency phone calls from pretty much any number....
    So Bump for help..
  4. #4
    Bobman's Avatar
    Posts
    Global Posts
    207 Global Posts
    Quote Originally Posted by ioo View Post
    I will second this suggestion. There may be a standalone app that does only what you are talking about, but I use Tasker.
    What I do is set it so my notification sounds turn off if it is between certain hours AND if my phone is plugged in (ie charging by my bed). I also set a lower ring and other options. I don't screen certain callers because I don't get many calls if any in the night, but I'm sure Tasker can do that.
    You can just Google Tasker profiles and get various tutorials on how to get started. It is a powerful tool that is worth learning.
  5. #5
    this might be a start -
    Call Control - Call Blocker
    Kedlin Company
  6. #6
    This is what I use on my GN2. I love it!
    sent from my AT&T GN2
    Attached Thumbnails Attached Thumbnails What is the closest thing Android has to iOS's 'do not disturb' mode?-uploadfromtaptalk1362070043686.jpg
  7. #7
    Give a shot. It's similar to iOS DND but has instant 1-click mute timer for quick unplanned meetings and a few other things that aren't in the iOS Do Not Disturb. It works great!!!
  8. #8
    Little Darwin's Avatar
    Posts
    ROM
    Stock
    Another vote for Tasker, but a couple of other options too...
    If you don't mind a couple of steps, just shut off data (3g/4g) and wireless (802.11) when you go to sleep. Turn them on when you get up. There are a variety of widgets you can use to make this pretty easy (i.e. click one widget to toggle wireless, and another to toggle cell data).
    This also has the impact of notifying you about any of the stuff you would have received overnight as it is received after you wake.
    Another option is something like Juice Defender, where you can have it turn off data (both cellular and 802.11) . I have used this in a timed way, so I don't know how well it would be for toggling on a varied schedule... different apps of this type may prove better for you.
  9. #9
    hi gadgetgirl could you tell me what app this is as i would like to give it a try .
    I am looking for a app that lets anyone phone me (even numbers that dont show up) at night, but mutes emails,texts and notifications.
    thanks
  10. #10
    hi i have found it for anyone else looking, on my galaxy s4 its called blocking mode in my device, and its exactly what i wanted.
    now for some peaceful sleep
    Thanked by:
    GadgetgirL76 likes this.
  11. #11
    Llama would work for this as well.
  1. What is the file we're supposed to rename in CWM?
    By greydarrah in forum Verizon Galaxy Nexus Rooting, ROMs, and Hacks
    Last Post: 01-11-2012, 05:08 PM
  2. what is the best free website/app to watch live television?
    By stickman1220 in forum Verizon Droid Incredible
    Last Post: 09-15-2011, 12:05 PM
  3. what is the best micro sd card to use?
    By thepanttherlady in forum T-Mobile HTC Sensation
    Last Post: 07-05-2011, 10:06 AM
  4. What is the MAIN Thing
    By RkyMtnHigh in forum Samsung Galaxy Tab 10-inch
    Last Post: 06-26-2011, 02:25 PM
  5. What is the first thing you'll do with your Epic?
    By Andrew Ruffolo in forum Sprint Epic 4G
    Last Post: 08-23-2010, 04:00 PM
