Re: snapchat camera problems
yeah ive been having the exact same problem but on my htc cha cha, no idea why and ive tried everything to fix it but nothing works. has anyone got any idea what's going on? or what we can do? maybe its the same for all androids but i havent heard anything..
Im having the exact same problem with the droid 2 global. Searching everywhere for the fix. I downloaded the updated patch for snapchat and it still did not fix
Michael, I too have been searching all over for tany solution to this problem and have found nothing. May I ask thought where you found the update patch for snapchat? I know you said it didn't help but it couldn't hurt giving it a try.
Thanks
Sent from my DROID2 GLOBAL using Android Central Forums
I am having the same problem hayley, did you manage to fix it?
Having the same problem! Any solutions?
