DEAL OF THE DAY: Save 42% on the iBOLT Vehicle Charging Dock for Samsung Galaxy S3!
Results 1 to 5 of 5
    Default snapchat camera problems
    Hello everybody,
    i am having some problems with snapchat. I had no problems with it a few days ago when i was using my droid 2, but a couple days ago i switched to the droid 2 global l because i plan to travel overseas here in a couple months. And since i switched to the droid 2 global snapchat has been acting weird. The problem is that when i take a picture now, holding it portrait style, the phone or app i am assuming rotates the picture 90 degrees and stretches it out and makes it look awful and so i have to hold the camera landscape to take a picture so that it will rotate it 90 degrees and look somewhat normal but it still has this stretched look to it. I have tried to find some way to change this in the settings but can't find it anywhere in the settings, also i assume its the app because the camera app on the phone works perfectly just in snapchat i have the problem. i have tried uninstalling it and reinstalling multiple times and trying to clear the data under manage apps and i have logged out and back in and i dont know what else i can try. has anyone else been having this problem too? any help would be greatly appreciated. Thanks!
  2. #2
    Default Re: snapchat camera problems
    yeah ive been having the exact same problem but on my htc cha cha, no idea why and ive tried everything to fix it but nothing works. has anyone got any idea what's going on? or what we can do? maybe its the same for all androids but i havent heard anything..
  3. #3
    Im having the exact same problem with the droid 2 global. Searching everywhere for the fix. I downloaded the updated patch for snapchat and it still did not fix
    Michael, I too have been searching all over for tany solution to this problem and have found nothing. May I ask thought where you found the update patch for snapchat? I know you said it didn't help but it couldn't hurt giving it a try.
    Thanks
    Sent from my DROID2 GLOBAL using Android Central Forums
  5. #5
    I am having the same problem hayley, did you manage to fix it?
  1. Autofocus/Camera Problem
    By Nese2009 in forum Motorola Droid
    Last Post: 05-04-2010, 11:59 AM
  2. Anyone experience camera problems?
    By CMCarlin in forum HTC Droid Eris
    Last Post: 03-01-2010, 06:51 PM
  3. Camera Problem
    By ethan in forum Motorola Droid
    Last Post: 02-15-2010, 12:13 PM
  4. Weird camera problem
    By sdelgado4 in forum Motorola Droid
    Last Post: 12-10-2009, 07:23 PM
  5. My Droids camera problem.
    By Mrwatch921 in forum Motorola Droid
    Last Post: 11-15-2009, 03:39 PM
