Results 1 to 3 of 3
    Default Urgent Android Help
    I'm having trouble with my newly bought Galaxy S3. It has to do with downloading applications. When I download apps from the marketplace I have no trouble. The problem is when I attempt to download and install third party applications. I have the box ticked where you can download third party apps, that's not the problem. The problem is when I download the app and click on it to install it, the installation button did absolutely nothing. It makes no motion our vibration, it's as if nothing had ever happened. I did try unchecking the box and restarting my phone, neither of those things work. Any help would be grateful. I am not rooted. Thanks, Aaron.
  2. #2
    sledge007's Avatar
    Posts
    Global Posts
    6,876 Global Posts
    ROM
    Wicked Sensations
    Default Re: Urgent Android Help
    Did you go into Settings/Security/Device Administration and check off "Unknown Sources"?
  3. #3
    Quote Originally Posted by Aaronandroid View Post
    Are you using Screen Filter or any app that lowers the screen brightness lower than system default? Turn it off and things should work fine.
  1. Moving from WebOS to Android... help needed
    By tommygun in forum General Help and How To
    Last Post: 12-16-2011, 04:31 PM
  2. IPhone 4 to android help
    By Joshyy_rey in forum AT&T Captivate
    Last Post: 09-12-2010, 09:12 PM
  3. Berrybuzz for android??? HELP
    By hondaboi2000#ac in forum Android Applications
    Last Post: 08-23-2010, 12:54 PM
  4. Need Android help?
    By androidzone in forum General Help and How To
    Last Post: 08-15-2010, 07:08 PM
  5. double click to execute on a website. Can it be done on android? Help!
    By b737thurman in forum General Help and How To
    Last Post: 07-19-2010, 05:43 PM
B
