Results 1 to 3 of 3
- 01-30-2013, 08:33 AM
Thread Author #1
Make TFC tags toggle without using Tasker!
Hi
All over the net, I see that people have made NFC tags, and make them toggle beteen settings. For example turning wifi off, gps on, bluetooth on when they enter the car, when they exit the car, they just hit the tag again, and then the settings will be set as they were before (or just set to some other setting).
As far as I see, you have to use the Tasker app to make it. Does anyone know of any other app, that can do it ? - 01-30-2013, 04:02 PM #2
Re: Make TFC tags toggle without using Tasker!
Yep, you can use NFC Task Launcher.
Go to MY TAGS, click on the top right to add a new tag, then scroll to the screen on the right where it says TASK 2 and you can create a Switch Tag. - 01-31-2013, 08:36 AM
Thread Author #3
Anyone using Tasker? Have any tips?
By braj in forum Android ApplicationsReplies: 11Last Post: 06-15-2011, 04:51 PM -
Unrooting without using pc?
By EVO1Android in forum HTC EVO 4G Rooting, ROMs, and HacksReplies: 2Last Post: 01-01-2011, 04:44 PM -
Anyone use Tasker?
By JoshH in forum Android ApplicationsReplies: 4Last Post: 08-09-2010, 07:13 PM -
Using Tasker to change A2DP Bluetooth settings?
By CouchFisher in forum Android ApplicationsReplies: 1Last Post: 07-26-2010, 06:35 AM -
How do I unlock phone without using touchscreen?
By SusanHome in forum Motorola DroidReplies: 11Last Post: 02-05-2010, 09:40 AM
Reply
