Help. how to export firefox bookmarks?
Hi:
I'm looking for a way or app that allows me to export firefox (mobile) bookmarks, to a html file for instance.
I've been looking for but with no luck...
The thing is that i formated my PC and I lost firefoxsync's recovery password, so the only option is to ask for a new one, but i will lost all he data.
So I was thinking that exporting bookmarks from my android, then import them to firefox and then syncronizate it to firefoxsync might work for not losing anything...
Re: Help. how to export firefox bookmarks?
you don't need a recovery password, just goto your firefox mobile's settings->sync->pair a device. It will ask you for a 9 character passkey randomly generated by your desktop browser when you select the sync option in it.
This process doesn't ask for your recovery password at all, and will sync all your firefox mobile's settings over.
Hi,
I have the last version of Firefox in my galaxy note, but I don't have the option to pair a device... Thanks anyway....
Anyway, I solve my problem with an extension for Firefox called FEBE. It save my day and I forgot I had it installed...
BR
Enviado desde mi GT-N7000 usando Tapatalk 2
thanks, great to hear.
my firefox on android has the pairing other device function, although i have so many versions of it. i think it should be there when firefox 19 is released to android today.
