Results 1 to 2 of 2
- 08-26-2010, 01:39 PM
Thread Author #1
GrooveShark vs Battery
Recently my battery life took a dive. Around the same time, I installed Grooveshark. About this phone didn't give me any useful info, although in the past it has. It was saying nothing about Grooveshark using up battery life.
I did notice that I would get warnings that Grooveshark was losing its internet connection, even though I wasn't using it.
A couple of days ago I removed it as a test. I've had excellent battery life since then. Coincidence? Have others had Grooveshark eat batteries?
Using Froyo on an original Droid. - 08-26-2010, 04:09 PM #2
Re: GrooveShark vs Battery
No problems here, but I properly exit the app when I'm finished using it. Maybe it stays running because you use the back button to exit rather than choosing QUIT from the menu.
Sent from my PC36100 using TapatalkSend files between your Android and your PC with Dropbox - Click here
Reply
