Results 1 to 4 of 4
    dcdoes's Avatar
    Posts
    Global Posts
    32 Global Posts
    Default doubletwist does not work on OS 10.4.11
    Yes - I searched
    I am trying to sync my iTunes using DoubleTwist - but it requires OS 10.5 and above. I have VMware with XP running, so I could move the files over but it is tedious.
    Does anyone know of an app like doubletwist that will run on OS 10.4.x
    BTW - The DX came this morning and it is awesome. Bye-bye Storm!
  2. #2
    Default
    PPC or Intel?
  3. #3
    dmnall's Avatar
    Posts
    Global Posts
    630 Global Posts
    ROM
    Latest AOKP!
    Default
    Try upgrading to 10.5 or 10.6 *10.5 is the last ppc* while 10.6 is Intel Only!
    HTH,
    Charlie
    Samsung Captivate - RIP 10-6-2011 Currently: Samsung Galaxy S2 i777 - Rooted, Sim Unlocked and soon to be debloated
    dcdoes's Avatar
    Posts
    Global Posts
    32 Global Posts
    Default
    I have an Intel based macbook but the dvd drive is bad. I wound up moving my music over to a windows VM and doubletwist works. Problem solved. Btw one day with the DX and loving. It
