Results 1 to 3 of 3
    Default I have a problem with my bank application ??
    Hello
    Well iam using my bank application on S3 android
    I have used it for 3 months now and I did too successfully operation using it( transfer funds). However for the last 2 weeks I was trying to do transfer funds operation and it did successed. After I confirm the transferred amount I waited for the One Time Password(OTP) flash to show so that I can inter the number and finish the process but i did not showed for long time. Is this problem an application problem or is it Android problem.
    I was thinking that it is Android as few weeks back my memory was full and a message , like this " delete some application or some function will be sync" showed. I can notremmber the exact message. I deleted some photos and videos to restore enough memory space. Does this problem has anything to do with Sync account??!!!
    where should I troubleshoot?!
    iam looking forward to your reply and suggestion
  2. #2
    Default Re: I have a problem with my bank application ??
    Hello.
    First I would check and make sure you have eliminated what you can to keep a reasonable amount of free space on the device so you don't run into the low storage space warning again.
    Second.. Did your S3 recently get the update to 4.3? If so it is very possible the banking app your using maybe in need of updating to support 4.3.
    Paul
    Moderator Team Leader @ Android Central
    hallo Paul627g
    Well i have checked the version and it is Android 4.1.2!!
    yesterday I took a lot of videos and photos and the phone give this notification" storage space running out , some system functions may not work"
    is this could be the problem to the bank app.
    looking for your thought on this.
    thanks
  1. My Galaxy Note 10.1 (2014) has a dark screen.
    By RaxGhost in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 04-01-2014, 01:52 PM
  2. Devise language- options have been reduced
    By reema23 in forum Samsung Galaxy S3
    Last Post: 01-19-2014, 12:49 PM
  3. Text messages not coming to my phone.
    By shyind in forum Samsung Galaxy S4 Mini
    Last Post: 01-18-2014, 07:15 AM
  4. Note 2 not showing up on My Computer and Note 3 not recognized by kies or PC
    By Ahmed Hesham in forum General Help and How To
    Last Post: 01-18-2014, 03:38 AM
B
