Results 1 to 3 of 3
    Default need help pls -
    i bought my child am android phone from a DX.com.good specs for the price , the phone is KINGWILL 5 inch. suddenly we start seeing apps/icons on home screens , which some are inappropriate. at first i thought the kid did that, but after uninstalling them, deleting icons, they kept coming back. some where just games and some were links or apps of pornographic sites. i installed AVAST and AppBrain Add detector to see which apps were installing these other apps . some of the apps on my machine are in chinese and i dont understand them, and i have a lot of icons that have the android symbol and i dont know which are necessary for the OS of the phone and which are mallware. i guess something has rooted me. pls help how to figure this out . (i have 4.2.2 android OS). PLS HELP
  2. #2
    Default Re: need help pls -
    Welcome to Android Central! I don't think you're rooted--I think something just got a hold of your phone. It's hard to pinpoint, but it could have been malware in an app that someone installed at some point. At this point, it's probably best to do a full factory reset. Before you do, go to Settings>Backup, and uncheck "Automatic restore" if you have that option. This is to prevent apps from automatically re-installing after you do the reset, just in case one of them is malware.
    Then, go to Settings>Backup, and tap "Factory data reset." This will wipe your phone, so make sure your contacts and any other important data are backed up or synced somewhere first.
    Good luck!
    Thanked by:
  3. #3
    X2 on the factory data reset
    dpham00, Android Central Moderator
    Sent from my Verizon Samsung Galaxy Note 3 via Tapatalk Pro
  1. Galaxy S3 owners is the S5 a good enough upgrade for you needs?
    By HOLLYWOODANT215 in forum Samsung Galaxy S5
    Last Post: 02-26-2014, 06:26 PM
  2. S4 4.3 hotspot how to..I need help
    By limpingzombi in forum General Help and How To
    Last Post: 02-25-2014, 05:02 PM
  3. Help With Text Messaging Issue
    By IceCold803 in forum Samsung Galaxy Note 3
    Last Post: 02-25-2014, 02:15 PM
  4. htc one wifi problem help plz
    By tipu77777 in forum HTC One
    Last Post: 02-25-2014, 01:44 PM
  5. Need Help to Flash Evo LTE back to Sprint
    By vikingwarrior in forum HTC EVO 4G LTE
    Last Post: 02-24-2014, 06:10 PM
B
