Control Shortcuts
New customer.
After figuring out how to change default widgets to control shortcuts (4G, Wireless, Bluetooth, etc), tried a few.
General Observations:
State of item (eg 4G) is unclear. Text above icon says "ON", but in case of 4G it means radio ON - yet in my area there's no 4G service.
Suggest that these icons change shade depending upon status.
Status OFF: shade = faded Text= OFF
Status PRESSED: shade = brighter Text = WAITING
Status ACTIVATED: shade = brightest Text = ON
The main issue I have is that when pressing a button I have no feedback to indicate that the request is in work. Therefore I press it repeatedly (dumb user) as I am impatient. This just apparently cycles the commands and as I have not been paying attention I have no idea what state it's in.
The 4G is a good example as it takes 30 seconds or so to get lock. And if you don't, the radio is on and wasting power. So good to know that it's "in work", then user can decide to give up and press button for off.
Same for wireless, but delay is sometimes less. Still if no WWAN available it will just sit there dumb fat and happy saying ON when there's nothing connected.
Hope this description helps.
