Results 1 to 5 of 5
    jsaren's Avatar
    Posts
    Global Posts
    83 Global Posts
    Default Connectbot and Port Forwarding problem
    Here is my problem I am trying to access my work computer using port forwarding with connectbot and then Android VNC Viewer, and I can not get it to work. I am not sure if I am setting up something wrong. I have secureCRT setup on my mac with Real VNC viewer and it works great just can not get it to work with Android. I have attached a screen shot of my port forward settings from my secure CRT on my mac and also my VNC viewer . I am able to SSH into my work server and connect using connectbot. However I am not sure if I am setting up the port forwarding in Connecbot correctly. Here is what I am doing based I the way I am interpreting it.
    ConnectBot
    Local
    Nickname: work
    Source port: 5902
    Destination: I have tried both (localhost:5902 and 127.0.0.1:5902)
    Remote:
    nickname: work
    Source Port: 5900
    Destination: 216.107.198.140:5900
    Android VNC
    IP: 127.0.0.1
    Port: 5902
    Any suggestions on why it does not work would be appreciated
    Attached Thumbnails Attached Thumbnails Connectbot and Port Forwarding problem-screen-shot-2010-09-27-12.52.16-pm.jpg   Connectbot and Port Forwarding problem-screen-shot-2010-09-27-10.16.19-pm.jpg
  2. #2
    Default
    I had a similar issue with my setup (Android VNC/Connectbot). I ended up using one of the other VNC clients available, and it works fine now. I'm guessing its a bug in using non-standard ports with the Android VNC client. This is the one I am using now:
    He has a lite version and a paid version (which I ended up getting)
    jsaren's Avatar
    Posts
    Global Posts
    83 Global Posts
    Default
    Thanks I just tried the one that you recommended and that does not work either
  4. #4
    Default
    I don't have my phone handy at the moment, but under connectbot's port forwarding, you need to point to the real IP address/port on your destination network. The source port obviously needs to be whatever you use on the vnc client. (connecting to 127.0.0.1)
    jsaren's Avatar
    Posts
    Global Posts
    83 Global Posts
    Default
    Quote Originally Posted by liquid64 View Post
    All set I figured it out thanks
B
