Results 1 to 4 of 4
    admsteck's Avatar
    Posts
    Global Posts
    36 Global Posts
    Default Simple battery and signal widget
    I am trying to clean up my main home screen and have settled on launcher pro with the notification bar hidden, beautiful widgets, and only the phone in the bottom dock. I really like this set up so far with the exception that I cannot see the battery or signal "bars". Can anyone point me to a simple and clean looking widget that will show these on my home screen? Thanks.
  2. #2
    Sabban's Avatar
    Posts
    ROM
    Community Rom 2.0
    Default
    I use Moble Signal Widget and it works well and of course is free on the market
    Thanked by:
  3. #3
    packerbacker's Avatar
    Posts
    ROM
    Stock Deodexed Froyo
    Default
    Thanks- I'm going to pick up this widget also! I too hide my notification bar with Launcher Pro.
    Superbowl XLV Champions!
  4. #4
    geocomp's Avatar
    Posts
    Global Posts
    121 Global Posts
    Default
    I use System Info Widget. It has a battery and a signal icon along with some other info.
