Results 1 to 7 of 7
- 10-21-2010, 08:10 AM
Thread Author #1
Angry Birds Help
Looking at one of the Angry Birds walkthru videos (1-12) I noticed that the birds split into 3 or 4 birds halfway through the flight. How do you do that?
- 10-21-2010, 08:12 AM #2
The small birds will spit when you tap on them in flight. There are a few other birds that have actions once touched.
- 10-21-2010, 08:13 AM #3
You don't have to tap the bird. Just tap the screen.
AFAIK, all birds do something when you tap the screen. It's just that the red ones only make a noise. - 10-21-2010, 10:57 AM #4
Red birds actually pack quite a punch. The farther they travel before hitting the target, the harder they hit (hint... high trajectories give them a lot of speed and hit really hard), as well they're great for knocking over tall structures. They're more like a battering ram.
"Some see the glass as half-empty, some see the glass as half-full. I see the glass as too big."
- George Carlin - 10-21-2010, 12:26 PM #5
red birds=increased punch with distance
blue birds=ability to split into several smaller birds
yellow birds=ability to speed up when tapping the screen - 10-21-2010, 12:54 PM #6
- 10-21-2010, 01:42 PM
Thread Author #7
Thanks to everyone.
Reply
