Results 1 to 9 of 9
    Default Need help finding a podcast manager
    Hey everyone! So, there are two morning shows I like to listen to at work. Since they both have podcasts, I like to download and then listen to the entire show. I've been using Google Listen for a while, but would like a better podcast manager. The reason I don't like Google Listen, is because of it's inability to sort by oldest first.
    For instance, both of the shows break their morning show into 19 or 20 podcasts a day (that way they can cut out the commercials/music). However, most podcast managers I have found either only allow 4 or 5 recent episode downloads or don't have the ability to sort.
    Does anyone know of a podcast manager that would allow me to download all 20 or so of the podcasts that have come out in the past day and sort with the oldest first. Like I said, Google Listen does everything I need, except it puts the newest episode in the playlist first.
  2. #2
    Default
    Go to this site and this should be your go to site for apps in the future but I found podcast managers you maybe interest in.
    Thanked by:
  3. #3
    MowDownJoe's Avatar
    Regular lawnmower man...
    Posts
    ROM
    Stock
    Default
    Go and tell the guys making Winamp for Android that you want to use WinAmp to play podcasts.
  4. #4
    exmeaguy's Avatar
    Posts
    Global Posts
    365 Global Posts
    Default
    Feedr is a great app that will do what you want. It's $2/3 in the market and worth every penny. Snychs with google.
  5. #5
    Nick8539's Avatar
    Posts
    Global Posts
    119 Global Posts
    Default
    I love using beyondpod.
    Sent from my PC36100 using Tapatalk
  6. #6
    jimsearle's Avatar
    Posts
    Global Posts
    17 Global Posts
    Default
    Podtrapper does everything you want and you can get a free 30 day frial version from his web site
    Sent from my SAMSUNG-SGH-I897 using Tapatalk
  7. #7
    Default
    You might give Doggcatcher a try. It's my fav atm for podcasts. On the displaying the newest casts first it has an option to sort that's in a experimental stage, but even if the list is displayed newest at the top it will start a new feed w/ the oldest podcast so say you finish listening to the first morning show it will then move on to the second one, but it will start w/ the oldest one downloaded,
  8. #8
    Pre-dawn raid's Avatar
    Posts
    Global Posts
    320 Global Posts
    ROM
    stock 4.2.1; CM7.2(nook)
    Default
    A lot of people swear by Doggcatcher but I have PodTrapper and this will do exactly what you want. It's $7. 99 in the market and well worth the money. Read the comments and you'll see.
  9. #9
    Default
    Stitcher radio works great
