Good Power management for 2.2.1?
graffixnyc
88
Hi,
I'm looking for a power management app that I can set up profiles based on battery level and turn connections off accordingly. I'm looking for one that will turn off bluetooth, gps, sync, wifi and switch between 2g/3g automaticlly based on the conditions in the profile. I thin there is an app that does something like this called Power Manager but I also read it's old and hasnt been updated and doesnt work with 2.2.1.
Any help would be appreciated
for example:
full battery all connections are manual(set by system)
< 50% turn off wifi and bluetooth and gps
< 25% turn all above and sync
< 10% turn off everything including 3G and just use 2G
guylenn49
