Results 1 to 13 of 13
    Default Percentage battery indicator?
    Is there a free app out there that shows 1% increments? Not 10%....thanks..
    Sent from my MB860 using Tapatalk
    BILL
    GTALK: bubba.komar@gmail.com
    Liveprofile: LPTWBRQW
  2. #2
    aruth09's Avatar
    Posts
    Global Posts
    114 Global Posts
    ROM
    Stock
    Default
    I'd be interested in something like this. Ive always had a battery percent patch on my pre. I'd like to have one when I get my evo 3d. Ive seen an app that adds a percent to the notification bar but it dosn't replace the old battery icon
    Sanyo basic Flip phone- Moto Krazer- Moto Razer2- Palm Pre - Evo 3D
  3. #3
    bigk's Avatar
    Where's the juice again?
    Posts
    Global Posts
    399 Global Posts
    ROM
    Stock
    Default
    I don't understand the point of this.
    If your at 93% obviously your battery pretty much full. If your at 8% you need to find a charger because your phone is about to die.
    I'm finding it hard to see the difference between 56% left compared to 50% left on the battery. I mean I could see you looking at the extra 6% and knowing that I got 4 hours and 12 minutes left. (Compared to just knowing you got roughly 4 hours.)
    For me I don't really worry about it and charge it in the car or at home when needed.
    Feel free to private message me at any time! I enjoy getting private messages.
  4. #4
    esrakes24's Avatar
    Posts
    ROM
    SC 2.9.2 ComaVolt
    Default
    you can try Elixir it has a battery display that goes down in 1% increments
    Default
    I dont want one with all that extra stuff with it...hmmm.....
    BILL
  6. #6
    jkatzpac's Avatar
    Posts
    Global Posts
    5 Global Posts
    Circle battery widget gives percentages in 1% increments.
  7. #7
    Default
    I use Gauge Battery, it has been a good little app for me.
  8. #8
    TWC_SouthPhilly's Avatar
    Posts
    Global Posts
    954 Global Posts
    ROM
    CM9...on both devices
    Default
    Try "Barrett Mix"... its in the market. Dose the 1% thing and offers a usage graph and a few other toys.
    Sent from my MIUI havin, Gingerbread Throwing EVO
    Devices: Samsung Galaxy SII Epic Touch 4G
    Samsung Galaxy10.1 16gb, Wifi
  9. #9
    Default
    I think you were looking for something that would show percentage in the notification bar, but others are posting widget recommendations, so here's mine...
    Battery Monitor Widget
    Show 1%. Shows mA and mV info. Keeps a log file which is great when you're trying to figure out when and why your battery is discharging quickly and if you want to see the minimum drain on the battery while asleep. And graphs the info.
    I used to use Gauge Battery until I found this.
  10. #10
    Default
    What I use isn't free (there is a free version though), Battery Monitor, shows a big clear % in the status bar rather than small numbers on a white battery icon or inside an outlined battery icon, which aren't as easy to see. I had Battery Alarm on my older phone, it beeps when it reaches a set % (like 20% battery).
    I'm not sure if it's app specific, as I've seen the same app give 1% increments on many phones but only 10% increments on Motorola phones (my old Motorola Quench and Charm would only work on 10% increments).
    HTC Desire / CyanogenMod 7.1
    Motorola can kiss my a##
  11. #11
    Default
    I dunno if you would like the style, but I use a minimalistic text widget. The standard style is nice, it doesn't take up much room, and it doesn't seem to take much juice at all to run. I love it, it's free. But it depends on the style you want for your phone. Mine is sideways and at like 83% it would say "EIGHTYTHREE"... You can see what mine looks like (sorta) on the "Post your thunderbolt homescreens" sticky. I think mine is still on the last page.
  12. #12
    Default
    Quote Originally Posted by bigk View Post
    You don't see the difference between having 56 and 50? Great! Please send me 56 dollars and I'll send 50 back! Oh heck, lets get to the chase. Send me $5,600 and I'll send 5 dollars back. It's only a difference of scale, right!
  13. #13
    prakash99's Avatar
    Posts
    ROM
    GummyNex 0.3.8
    Default
    Quote Originally Posted by jkatzpac View Post
    I like that one myself, I've been using it for a long time.
    Sent from my ADR6400L using Tapatalk
