Results 1 to 16 of 16
    Default Google Music "first track" problem
    I've got a weird bug with Google Music. When I play an album that's in the cloud, the first track plays twice, then there's silence. The whole time, the time counter on the left side of the status bar is ticking.
    So, I just started a remote album for which the first song is 3:06. It played the song, then played it again with the play time ticking from 3:07 to 6:12, while the length is still correctly displayed as 3:06 on the right side of the status bar. The song finished for the second time and there's silence, but the clock is still ticking (currently 14:24 and counting).
    If I press the "next" button, it will continue through the songs as expected.
    Anyone else seeing this?
    For reference, this is rooted froyo.
  2. #2
    M_i_k_e_B's Avatar
    Posts
    Global Posts
    18 Global Posts
    ROM
    4.0.2/4.0.3
    Default
    Rather than going into the folder and clicking on the first track, have you tried tapping and holding on the folder (album) name and them selecting Play? That solved the same issue for me.
    Default
    Quote Originally Posted by M i k e B View Post
    Hmmm... nope. Same behavior. Here's what I did...
    1. Get to "Artists" list
    2. Tap one to show the list of albums
    3. Tap & hold an album entry until the menu pops up
    4. Choose Play
    Same behavior I described above.
    Just for the sake of trying, I just did the same thing, but tapped the album entry to show the list of songs. Then I tapped the second track to play it. I got the same behavior - song repeats once, then silence.
    Very odd. I think my solution to the issue will be to return to Power Amp and try Google Music again later. :-)
    Thanks for the info, Mike.
  4. #4
    Default
    It happens to me too. Very annoying.
    "They don't think it be like it is, but it do." -Oscar Gamble
    Droid X (Liberty 3 v2.0)
    Droid Incredible (CM 7.2.0 RC1)
    Nook Color w/ 8GB N2A card
  5. #5
    terpitude71's Avatar
    Retired Moderator
    Posts
    Global Posts
    2,164 Global Posts
    ROM
    CodeName Android 1.5.5
    Default
    same here. also quite annoying. im sure its a bug that just needs squashing in a future update
  6. #6
    Default
    That didn't take long! I just had an available update for the Music beta app, installed it, & now it goes to the 2nd track as it should.
    Default
    Whoa, imagine my surprise when I clicked on the "some bug fixes" link on the front page and see my name staring back at me! Nice.
    Thanks for verifying, El Jefe, I'm downloading now.
  8. Thread Author  Thread Author    #8
    Default Only partially fixed
    I've got v3.0.1.339 and I'm still seeing the problem in one use case.
    Here's what works:
    - Tap artist name to display list of albums.
    - Tap and hold album name and select Play from the pop-up
    Here's what still fails:
    - Tap album name to display list of songs
    - Tap song to play
    Same behavior as before... the song plays twice, then silence. The clock continues running, displaying times far greater than the song length.
    Anyone else able to reproduce this?
  9. #9
    Default
    I'm experiencing this exact same issue, also on the latest version of the music player.
  10. #10
    ckelly33's Avatar
    Posts
    Global Posts
    132 Global Posts
    Default
    I get the repeating track despite using the method you suggested. It also isn't limited to the first track for me.
    Quote Originally Posted by Jack in NC View Post
    Here's what works:
    - Tap song to play
  11. #11
    Default
    I have the latest version of Google Music and I am still having the issue. I listen to music by Genre. If I select a song to play and then shuffle. Every so often a song will repeat and then after the second playing it will go silent. All the while the progress bar continues.
    Example is a song is 3 minutes long it will play twice and the progress bar will be a 6 minutes at the end of the second playing and then it will continue with no sound. To test it I let it run once and it was well over 20 minutes of silence. If you hit the advance key it will go to the next song, which is a huge problem when I am in the Car since I have to grab the phone, unlock and hit next.
    Hope it gets fixed soon, love the service. If anybody knows a work-around I would be all ears.
  12. #12
    NotJustAPhone's Avatar
    Posts
    Global Posts
    10,115 Global Posts
    ROM
    GS3: CleanROM / N4: AOKP
    Default
    You may want to submit this issue to Google.
    Sent using Tapatalk
  13. #13
    Default
    Glad I found this thread. Thought I was the only one going crazy with this. I've got the latest version and am having the same problem. First track plays twice, then nothing. But I've also got this happening to random songs within an album.
    Hope they fix soon. Where can we report?
  14. #14
    Default
    It still happens to me. I thought the update fixed it permanently but after a while it started happening again.
  15. #15
    Retired Moderator
    Posts
    Global Posts
    2,164 Global Posts
    ROM
    Default
    been all good for me since the update came out. lucky, i guess
  16. #16
    Default Re: Google Music "first track" problem
    trial and post for music
