anyone use both?
I've been using battery widget but really would like something in the notifaction bar instead.
battery indicator seems to work well but the icon stays white and is a little blurry.
battery status pro turns green, look perfect but seems to be using a bit more battery for it to run.
thoughts??
thoughts??
