I've always been using link2sd before, but then I realized that when I got my new phone I can't cleanup my 2nd partition. So basically anything I uninstall or move from the 2nd partition remains there and then messes up my apps and takes up huge amounts of memory.
I was wondering if somebody out there has the same problem as me, or perhaps there's another app that could clean up the 2nd partition. Been looking for something like that all morning and can't find any.
Cheers and thanks for the help in advanced!
P.S. I already posted this problem as a review on the Play Store. But am not sure if there was a compatibility issue with my phone or something. A workaround would be better
