1. bulldog's Avatar
    Has anyone heard of or made an app to use your phone to remotely open the locks on your car like a key fob ?
    11-24-2010 12:12 PM
  2. CallerHoller's Avatar
    I could see an app for a service like On Star, but I have no idea why you think an app can take the place of a device that transmits on a specific frequency with proprietary security codes.
    MowDownJoe likes this.
    11-24-2010 02:29 PM
  3. EVO1Android's Avatar
    The only thing I have heard of is the Viper SmartStart which is a remote start all in one:
    Viper SmartStart app goes to 2.0, gets potentially cheaper and throws roadside assistance into the mix -- Engadget
    pmendoza502 likes this.
    11-25-2010 12:43 PM
  4. takeshi's Avatar
    I'm not sure why people think that an app can replace hardware. Does your car have some sort of interface that allows for an app to unlock your car doors (this is what Viper SmartStart does)? If not you need to start there.
    Similarly, apps can't:
    1. Make your device replace infrared remotes to contol your audio video equipment (no IR emitter).
    2. Enable your device to receive OTA TV signals (no tuner).
    The list goes on and on. Just think for a moment and consider the chain of software and/or hardware needed to enable the functionality that you're asking about. What does your device include in its feature set? Does it have what it needs to accomplish what you're looking for? There are many apps that also require a service to enable their functionality (again, Viper SmartStart falls into this category as well as Schlage's solution and even Google Voice, among others).
    11-25-2010 01:20 PM
  5. Ms Charli's Avatar
    If Viper can do it I'm sure it will be available soon! So just keep a watch out out definitely not to far fetched!!
    11-26-2010 10:18 PM
  6. IIJBII's Avatar
    DroneMobile allows you (through an app after install) to unlock, lock, and start your car. Don't think this is what you are looking for but think its along the same idea. Its not cheap but it works pretty good (when you have good service).
    If you have questions please ask as I have one in my car and use it with my EVO.
    11-27-2010 07:01 AM
  7. Rickroller's Avatar
    I read yesterday about a guy who created an app called OpenSezMe that can be used to open garage doors. It requires some type of relay switch install as well.
    Android: Garage door opener app – OpenSezMe
    11-27-2010 09:35 AM
  8. bulldog's Avatar
    You would think ,that if Ford has the sync system installed ,it would be easy to do it.The radio trans/cever is already there for the key fobs.
    dsthinker likes this.
    11-27-2010 03:25 PM
  9. Paula Dnistrianskyj's Avatar
    I found several, the one that seems most promising does however cost $49.99 annually (Premium is more) but for a simple app that can unlock your can if you've accidentally locked your keys inside, is called Drone Mobile. Also found AutoNet Mobile, haven't tried it yet though (free app) and a very simple video on youtube which doesn't seem to require downloading or installing an app, according to the video, you lock your car with the remote, but keep holding the button down once the car is locked, at the same time press * 2x then # 2x then let got of the remote button. To unlock you then (close to your car window) press * 2x then # 2x then * again 1x, plan to try this one when I go out later
    12-22-2014 10:23 AM
  10. mojeep's Avatar
    Any updates on this?
    10-01-2015 02:01 PM
  11. appicator's Avatar
    Great, now all I need is a car.
    10-02-2015 04:08 AM
  12. Anton Tkachenko's Avatar
    Ok ****! That's a great app for lazy fatties like me =)
    10-03-2015 02:30 PM
  13. pmendoza502's Avatar
    Any updates?
    10-26-2015 03:11 PM
