I tried to find something about it, but ir really seems the is is not on the way yet.
What do you think if it was possible to install the Android Auto app in an old cell phone (or tablet), already attached into the car pannel, and hard-wired to the car radio and battery power, instead of nedd to buy an expensive device to install in the car? The old cell phone already has the most important, that is the bluetooth connection.
Someone heard something similar to that? It can be possible? Or, at least, do you thing it is a good idea to be implemented?
(thinking on this kind of system + a QI charger into the car, than you can simpy put you cellphone over the charger and let it connect to the Auto, seems really useful)
