A
AC Question
when i connect to google maps in the car via android auto it does not always work is this because there is not always 3g etc
So long as the map data is cached, yeah, it'll work.
Have you noticed that if you cache areas in Google maps, if you are navigating within the cached area, you wont see alternate route times while navigating real time?
i.e.: If you bring up alternate routes manually, it will say time differences, but when you're driving, and theres another route on the way, I dont see "x minutes faster/slower" when I have the map cached
Makes sense. It's not just using distance for those calculations, right?
