Help for a newbie Android Auto user please…..Just bought a Hyundai Elantra 2017 (which I LOVE). Using AA on a Nexus 5 running Marshmallow.
I know there are similar threads regarding messaging so forgive me as I am learning how to use AA and it’s not behaving as I expected it would.
Phone is linked into the car using USB and Bluetooth is connected. Charging is OK. I can listen to music OK. Maps are fine.
Main issue is that seemingly no matter which SMS program I use, be it Hangouts, Google Messenger, or GO SMS (preferred), it doesn’t seem to operate as anticipated.
I see the notification on screen of a message, but get no message alert sound, then with the exception of one occasion, when I tap the notification bar, it will not ‘speak’ the message.
I have no idea what happened differently on that one occasion though. Generally, when I press the notification bar, the system appears to go into ‘listening mode’ where it is waiting for a command.
As an aside, would I only see the notification if I have the AA screen displayed? I was expecting to get a visual notification on the Radio screen, but I suppose if I hear a notification sound (which I don’t presently) I can switch screens.
Any pointers would be helpful. Not certain at which end the issue lies (car/phone)
Thanks!
Thanks!
