What a cool contest. I spent my whole weekend in front of my laptop and with trial and error I managed to get something that looks
nice. I had so many more ideas including unicorns and space shuttles and stuff like that, but unfortunately a weekend is only two days ...
3D modelling is not something I do everyday, so I had quite some fun. I used Sketchup as a modeling tool, as that was the only tool I knew that was easy enough to do the trick.
Here is the front view of my result:
(For those who really can't see what it is, it's a phone/tablet stand)
Here is another view from the side:
I tried to fit in the
mobile nations logo in the design as well. The
frame around Lloyd is the orange frame from the mobile nations logo. Lloyd itself is supported by the mobile nations platform (you get it?
Most of the work was getting Lloyd in the correct proportions and tracing the 'androidcentral' and 'mobilenations' logos.
Here are a couple more pictures of the process:
- The finished version of Lloyd
- The tracing and the details of the 'androidcentral' logo
- an upclose view of the mobile nations platform
Sketchup can by default only export to obj format. So I installed the Cura software (I could do that without having the actual printer to print it) and it appears that it can hapilly import the obj file. But Russell suggested in one of the comments to export to stl, so I searched for a plugin for sketchup and exported to stl. Here you can find the link:
https://drive.google.com/open?id=0B7dtmBCcqgiSbXNCNzVjSFBIOEU&authuser=0
I'll also share the complete google-drive folder where the obj file is located as well:
https://drive.google.com/folderview?id=0B7dtmBCcqgiSfk8xcWxnT1FXYm9tTHlncVJYMXJrLVJvZTRZbzVOZUdZcDVKbWRrM3k0Z2c&usp=sharing
It's the first 3D-print desing I made, ever, so I really hope it is printable ...
Thanks again for the contest!
