1. EpicMelody's Avatar
    I have a Samsung Captivate and am trying to sideload apks. I download the SWM and put my phone in debugging mode. When I select the apk and click install, it says starting daemon... error:device not found. My computer is a Windows Xp laptop. Thanks.
    02-18-2013 04:08 PM
  2. DroidXcon's Avatar
    did you install the drivers?
    EpicMelody likes this.
    02-18-2013 04:39 PM
  3. EpicMelody's Avatar
    ?I see that as a popular response to questions similar to this. But what exactly does that mean? Bear with me, I'm new to this. I've had my Captivate for 2 years and have never really experimented much.
    02-18-2013 09:25 PM
  4. DroidXcon's Avatar
    Download and install this http://downloadcenter.samsung.com/co...s_5_02_0_2.zip
    afterwards restart your computer and connect your phone and try to use the application. afterwards let me know if it worked
    02-18-2013 09:29 PM
  5. EpicMelody's Avatar
    Installed and restart the computer, when I turned it on, the computer recognized and my Samsung Android for the first time and I went through the installation of the .zip files there. However, when I tried to use the SWM, I got the same device not found error.
    02-18-2013 09:42 PM
  6. DroidXcon's Avatar
    when you plug in the phone are you sliding the notification bar down and mounting it or are you simply plugging it in and running the program?
    02-18-2013 09:47 PM
  7. EpicMelody's Avatar
    I have my phone in debugging. I plug it in and see "USB connected" and "USB debugging connected." Then I run the program
    02-18-2013 09:52 PM
  8. DroidXcon's Avatar
    would you be willing to screen share with me so i can see what the problem may be? if not i understand
    02-18-2013 09:53 PM
  9. EpicMelody's Avatar
    I'm not sure what you mean, screen share?
    02-18-2013 09:55 PM
  10. DroidXcon's Avatar
    like i can remotely control your computer
    02-18-2013 09:55 PM
  11. EpicMelody's Avatar
    Sure. How?
    02-18-2013 09:57 PM
  12. DroidXcon's Avatar
    Sure. How?
    sent you a private message
    02-18-2013 09:59 PM
  13. DroidXcon's Avatar
    For anyone reading this thread with a similar problem , it seems he either had a bad cable or bad port on the phone, by pressing the cable in as he ran sideload wonder machine it was able to load.
    02-18-2013 11:04 PM
  1. [TIPS] for adb "device not found" error
    By Will Shanklin in forum Barnes & Noble Nook Color
    Last Post: 12-02-2011, 07:16 PM
  2. Attempting to root VC-error device not found
    By dwh1996 in forum LG Optimus S Rooting, ROMs, and Hacks
    Last Post: 02-27-2011, 08:29 AM
  3. ADB device not found
    By jcole01272 in forum HTC EVO 4G Rooting, ROMs, and Hacks
    Last Post: 07-29-2010, 06:39 PM
  4. error: device not found
    By jmcsmith in forum Incredible Rooting, ROMs, and Hacks
    Last Post: 07-13-2010, 03:46 PM
  5. 'Video too big for this device'
    By farowyn in forum HTC EVO 4G
    Last Post: 06-25-2010, 02:20 PM
