Daemon not running. ADB server didn't ACK
newbiehacker
SO i have the HTC inspire. which as you all know doesn't have the "Unknown Sources" button ata ll. so i downloaded the Sideload Wonder mAchine which would be awesome to use if i could get my phone to work with it. when i run the USB driver status it says
daemon not running. starting it now
failed to start daemon
error: cannot connect to daemon
i also downloaded HTC sync and my device can not be found on that either.
please help i am VERy new to this process so any and ALL ideas will be great. and if the answer seems obvious please let me know i literally just plugged my phone in for the first time to my computer and tried using the Sideload wonder machine
open up the computers task manager, find adb process and kill it, then try again
Reactions: acedanger
Your PC won't allow ADB to use port 5037. DroidXcon has listed the right steps to take.
If they don't work, you're going to have to see why your computer can't/wont allow ADB to use port 5037.
It's a local connection, so your firewall shouldn't come in to play, but check it anyway.
EDIT: Ignore this, looks like you have it sorted
Run over to sysinternals.com and pick up TCPVIEW and PROCESS EXPLORER, if you don't have them installed already.
For some reason, the ADB daemon is terminating before the close socket exchange is complete. If you run (from the command prompt) "NETSTAT -o", you will see the socket (generally 5037) in CLOSE_WAIT state and the owning process number. Process Explorer won't show that process ID (the daemon terminated), and the process called adb.exe (which opened the socket) will be gone. (If adb.exe if found, try killing the task and see if things get cleaned up.)
Using TCPVIEW, locate the hung socket. The process name column will show the associated process can not be found. Right click, and select "Close Connection". The socket is now closed, and the adb daemon should be able to start.
I tried everything, got frustrated and re-installed Eclipse + Android SDK .. still nothing.
I then got a feeling it was my Firewall, and even though I had marked adb.exe as a trusted file, I shut the Firewall down (or so I thought) ..... still nothing.
Only when I (after 2 frustrating days) uninstalled my Firewall and rebooted would I again be able to run my apps on the AVD.
P.S. I used the Comodo Firewall
Lelix2603
