Page 1 of 5 1234 ... LastLast
Results 1 to 25 of 114
Like Tree1Likes
    Thumbs down AC website bloated!
    I have been reading this website daily for well over a year now. Very good info. However, the new website is bloated with so much crap I can't hardly take it. It is just painful to wait for all the flash, twitter interfaces and such to load. I even tried it in a fresh IE browser and experienced the same thing. No my computer is running fine and clean. I understand that you have to pay bills to provide information, but wow do you have to make it painful to visit?
  2. #2
    Cory Streater's Avatar
    Forums Emeritus
    Posts
    Global Posts
    13,813 Global Posts
    Default
    Quote Originally Posted by parout66 View Post
    Hi Parout,
    Thanks for the feedback and sorry to hear you're not having an optimal experience. Are you referring to the forums, blog, or both? Based on what you're describing, I'm assuming your referring to the blog (Twitter feed and flash). If it's the forums, if you could list the specific "bloat" you're referring to that would also be helpful.
    Thanks,
    Cory
    Default
    Quote Originally Posted by Cory Streater View Post
    Hi Parout,
    Thanks,
    Cory
    Primarily the home page
  4. #4
    Major's Avatar
    Posts
    Global Posts
    638 Global Posts
    Default Browser problem
    My desktop PC can't open the Forums page for the site. I am able to render the home page, but when I click the Forums link it fails to load completely. This started happening a couple of hours ago. Has anything changed today that might have caused this, and what is the best way to fix it?
  5. #5
    Forums Emeritus
    Posts
    Global Posts
    13,813 Global Posts
    Default Re: Browser problem
    Hi Major --- Let me check on this.
  6. #6
    Forums Emeritus
    Posts
    Global Posts
    13,813 Global Posts
    I cannot replicate this. So, I need to gather a little more info.
    Quote Originally Posted by Major View Post
    My desktop PC
    Which browser?
    Have you cleared cache/cookies?
    Which of the following is true:
    1) Clicking the forums button (between Reviews & Videos) in the header at the top of the page?
    2) Clicking the link in the Navbar (e.g., the one above this thread)?
    3) Logged in or not logged in?
    When you say home page - are you referring to the blog?
  7. #7
    Major's Avatar
    Posts
    Global Posts
    638 Global Posts
    The browser in question is IE9. I have since switched to Chrome and it's working on that browser. However, it is still not working in IE9. Yesterday, when I would click the Forums button in the header, the Forums page would launch, but not finish rendering (i.e. I can't scroll or click on anything). Today, not even the home page will open completely. I get a pop up saying that www.androidcentral.com is not responding.
    I will play around with IE9's settings to see if I can get it to work, but in a worst case scenario I'll just use Chrome to visit the site. Thanks for the response.
  8. #8
    Default
    It's probably just Ie I had the same problem with Ie. It does that and then M$ will release an update and will stop for a couple of days and start back not loading web pages. My advice to you is stick with mozilla or Chrome. Ie is nowhere near as fast or stable as either and Ie has always been more vunerable to hacks and stuff.
    Sent from my PC36100 using Tapatalk
  9. #9
    thekraven's Avatar
    Posts
    ROM
    kraven cm7/CM9
    yeah same thingis happening with IE9 and the forums. Just hanging and freezing and finally loading after a minute. Started doing this for a day now. So far using Firefox to cruise here or changing to mobile on IE9 to make it work.
  10. #10
    Forums Emeritus
    Posts
    Global Posts
    13,813 Global Posts
    Let me check into what we need to do to become Microsoft compliant
  11. #11
    Default Connecting to Android Forums
    I apologize if this is not the place to post this, however since the problem is about my having a difficult time accessing the forum page, I felt I could ask the question here.. Up until a couple of days ago when I "clicked" to go to this page. It almost always connected immediately.. Since then it takes quite a long time to load, as well as when I select a thread it takes "forever" to load... etc.. Is it the "server" at the forum, something I need to "download" to correct, or do I have something set incorrectly? Thanks for your help in advance as not being a techno wizard guru geek I did not even know where to ask!!
  12. #12
    Forums Emeritus
    Posts
    Global Posts
    13,813 Global Posts
    Can you guys using IE9 try it again please?
  13. #13
    Huff's Avatar
    Posts
    Global Posts
    132 Global Posts
    Default Re: Connecting to Android Forums
    I have had the same issue. Usually ends up with Internet Explorer becoming unresponsive every time I try to go to forums. Other pages on androidcentral work fine.
    I found that I only have this issue with IE9. Forums work fine with Firefox 3.6. I did try adjusting IE9's security settings to no avail.
  14. #14
    Fable's Avatar
    Android Rules
    Posts
    Global Posts
    237 Global Posts
    ROM
    Tranquil Ice 7.0D
    Hiya Cory --
    Same thing is happening here with ie9 also.
    I dont have the problem through my Droid X browser or through my iPad... but since about when this thread started I get a freeze upon loading the forums section of the site. Its like a freeze of the whole page and it might have something to do with the way the ads are loading up top but I do not experience this on the main page at all.
    It happens everytime I move from one forum page to another (another forum, back to the top, open a single msg, etc.).
    I havent seen this on any other site.
    PS - Yeah its still happening.
  15. #15
    Moscow Desire's Avatar
    Troubleshooter
    Posts
    ROM
    Jiffy Pop Roots 3.47.114
    Right now, I believe there are some issues with regional access. Hopefully, they will be fixed by Monday.
  16. #16
    FrankXS's Avatar
    Posts
    Global Posts
    3,645 Global Posts
    ROM
    Latest OTA Official ROM
    Default Anyone else having issues with AC Website over the last few days?
    Over the last few days the forum pages are very slow to load. I've timed 'em at about 30 seconds each page. This happens every time I click on anything in the forums that brings up another page.
    I'm running IE9
    Also tried Safari - same thing.
    Also tried Chrome - better, but same thing
    I think it has to do with the content at the bottom of each page. Don't remember seeing that there before (footer?)
    Anyway, if I'm the only one I'm gonna start troubleshooting my system. If not, I'll wait it out.
    Thanks,
    P.S. I did send a note to the website admin - haven't heard yet. It is the weekend .
    I should add, a workaround is to use the mobile website: http://m.androidcentral.com.
    -Frank
    [HTC Thunderbolt™ 4G/LTE!]
    It's not your dream phone. It's the one after that!©
    Look here for a [VZW Coverage Map] to check your area. Select 4G before hitting [Refresh]
  17. #17
    Jalarm's Avatar
    Posts
    ROM
    Stock
    Default
    It was really slow for me 2 days ago. Loading fine now.
    Sent from my Desire HD using Tapatalk
  18. #18
    Paul627g's Avatar
    Posts
    Global Posts
    14,045 Global Posts
    ROM
    Milestone 1/Lean Kernel
    Default Re: Anyone else having issues with AC Website over the last few d
    I know our forum administrator Cory Streater has been constantly bringing new ideas and improvements to the users. It is possible some thing he has done to satisfy the user and also accomodiate advertising ads, etc has slowed access times down a bit. I'm not positive on this so don't take this too seriously until you hear from the man himself.
    Otherwise, AC just like any other forum sees its days where forum traffic is at high volume for reasons like a new device release or specific update that draws in the users in return putting a strain on the servers during those time periods.
    A simple look at the bottom of the main Android Forums section showing users online will help tell the story if the lag or slow response time is due to a sudden increase in online activity.
    Thanked by:
  19. #19
    FrankXS's Avatar
    Posts
    Global Posts
    3,645 Global Posts
    ROM
    Quote Originally Posted by Paul627g View Post
    Thanks Paul. Sorry, I never even knew about this "meta" forum . Not until someone moved my post here. LOL.
    Anyway, I now see a larger thread under this one on the same topic. Sorry about that... I don't think it's a local browser issue though. I have the same issue on all three browsers I've tried (safari, chrome, IE9). Also on different machines.
    Again, thanks.
    -Frank
  20. #20
    thekraven's Avatar
    Posts
    ROM
    kraven cm7/CM9
    It still does freeze after it loads, then it says "waiting a response from android central". Then the facebook, twitter, google+ load.
  21. #21
    PvilleComp's Avatar
    Posts
    ROM
    CM-7
    Cory - I've been away for the weekend and came back this evening - IE9 here as well - and every Forum page takes forever (30 - 60 sec) to load. I think it's the new footer - it's not rendering correctly there is a large gap between Signup - How to and Tags row and the Facebook/Twitter stuff.
    I blame Facebook personally
    Some say that his dormant chips were left that way for YOUR SAFETY... Others say that once "turned on," he can not be turned off... All we know is... He's called The Stig.
  22. #22
    Forums Emeritus
    Posts
    Global Posts
    13,813 Global Posts
    Hey guys - I was able to replicate what you were seeing earlier and disabled the footer until it's resolved. Sorry it was causing your browser problems earlier, but thanks for pointing it out.
  23. #23
    Castor Troy's Avatar
    Banned
    Posts
    Global Posts
    1,672 Global Posts
    ROM
    Project Elite/Raid Zero
    Default
    Stumbled on this thread by accident and thankfully I did. Reset IE twice to no avail. Good to know it wasn't on my end. Been driving me crazy all weekend lol.
    Gracias Cory for looking into the issue.
    Sent from my Droid
  24. #24
    Fable's Avatar
    Android Rules
    Posts
    Global Posts
    237 Global Posts
    ROM
    Tranquil Ice 7.0D
    Thanks Cory. All set here too!
  25. #25
    Major's Avatar
    Posts
    Global Posts
    638 Global Posts
    Thanks for fixing it! It was rather bothersome to have to use two different browsers.
