R
Ryan A
The default weather widget on my S5 is displaying only the clock and nothing else. Has anyone else has a similar issue?
I fixed the problem.
Go to Application Manager. In the right Tab "Unified Daemon" was disabled. You just have to enable it.
I hope this works for you too.
It worked for me also on my Note5. But in Application Manager I had to swipe from right to left to get to the DISABLED screen. There was "Weather Daemon" I enabled it and now all is good. Thanks!
