1. AC Question's Avatar
    Hi. I'm looking for a car mount that can accommodate my Galaxy S5 while it's in its Incipio case. I can find plenty of car mounts, but not one in which it fits with a case. Also, I'm not interested in a universal case, it has to be a dock for the S5 because I have an app, Tasker, that I'd like to program to recognize when it is docked in the car. Does anyone know of a car mount that fits these requirements? Thanks.
    06-13-2014 05:23 PM
  2. MobileMadness002's Avatar
    Docks are designed to fit the Device itself. If a universal is not an option then remove the incipio case. You do have choices, just a matter of the lesser desired.
    Sent from my Nexus 5 using Tapatalk
    06-13-2014 06:22 PM
  3. Gbsa's Avatar
    I use the ibolt with my note 2 in a rugged case. No need to take the case off.
    Sent from my NX785QC8G using Tapatalk
    06-13-2014 06:25 PM
  4. Peter9000's Avatar
    Docks are not always designed "to fit the device itself." Encased makes one that accommodates a case (but doesn't dock, just mounts the phone). And, to be clearer, I am looking for a solution where I do NOT have to exercise the choice of removing the case... if that's OK with you.
    I'll check out the iBolt. Thanks for that suggestion.
    06-13-2014 06:39 PM
  5. MobileMadness002's Avatar
    yep, it fine by me. carry on. looks like you already researched a couple options. good for you.
    06-13-2014 06:41 PM
  1. Replies: 3
    Last Post: 07-17-2014, 05:49 AM
  2. Slideshow app that will pull from my SD card?
    By MADDROID1 in forum Ask a Question
    Last Post: 06-14-2014, 12:19 AM
  3. Bluetooth link with car
    Last Post: 06-13-2014, 07:36 PM
  4. Budgeting app that doesn't connect to your banking information
    By icouldntpossiblycomment in forum Android Apps
    Last Post: 06-13-2014, 02:17 AM
  5. Replies: 0
    Last Post: 06-13-2014, 12:26 AM
