+ Reply
Results 1 to 3 of 3
    AC Question
    AC Question's Avatar
    Guest
    Default wifi problems
    Hi,
    I have a Samsung Galaxy S3 mini. I have a problem with my wifi that started yesterday afternoon. When i was done with the wifi i turned it off on the phone through the settings. When i came back to my phone i looked and i saw i had notifications even though i d=had turned off my phones wifi. So i turned it off again. It turned back on with out me even touching the setting tab. I turned it off and watched the tab moved from a gray square. meaning off to a green square meaning on. restarting my phone didn't help the wifi turn off it just kept turning on by itself. then last night it turned off and did not come back on again. Then today i turned it on to look ad my emails. it wouldn't turn back off and kept turning back on by itself again but this time the wifi would work for a few seconds then cut out. when i went to settings and looked at the next work it kept saying the network was out of range. I new it was not because i was sitting by the router. so now my wifi connections are not working with the phone and the wifi button/ tab on the hone keeps turning on even after i turn it off. Does any body know how i could fix this? Also i updated my phone tonight and that didn't help ether. Any suggestions about what to do for this wold be most helpful
    Thank you for your time
  2. #2
    Golfdriver97's Avatar
    Posts
    Global Posts
    32,718 Global Posts
    Carrier
    Pure Nexus/Franco Kernel
    Default Re: wifi problems
    Quote Originally Posted by AC Question View Post
    Hi,
    Welcome to the forums.
    When you are connected to wifi, in the settings>wifi, you should see the list of all possible connections. If you click on menu, that should bring up ADvanced options. Click that and see if there is a setting there that is keeping wifi on.
  3. #3
    Disable auto network switch
    Sent from my XT1028 using Tapatalk
  1. WiFi turns on automatically, how do i stop this?
    By maxima423 in forum Samsung Galaxy S4
    Last Post: 04-06-2015, 04:20 PM
  2. samsung galaxy s3 mini wi fi problem please help
    Last Post: 06-13-2014, 11:56 PM
  3. Another Consumer Cellular problem
    Last Post: 06-13-2014, 07:55 PM
  4. Replies: 1
    Last Post: 06-13-2014, 07:16 PM
  5. No network registered problem in galaxy y using hyperion rom
    Last Post: 06-13-2014, 06:27 PM
