+ Reply
Results 1 to 6 of 6
    AC Question
    AC Question's Avatar
    Guest
    Default stuck in manual mode after trying to restore factory settings
    galaxy s model sch-1500. home key takes me to and android guy and triangle with explantion point in it. volume keys will not scroll down to any options, power key does nothing. Ive tried to reset it with volume up/down key and power button , still comes back to this. says E: cant mount E: cant open E: unknown volume for path ... Any help would be appreciated, just got phone and tried to restore factory settings
  2. #2
    Default Re: stuck in manual mode after trying to restore factory settings
    this is my post, can anyone help? plzzzz
  3. #3
    Quote Originally Posted by needhelp01 View Post
    So you did follow these steps ?
  4. #4
    I went through setting to reset to factory, now doing those steps changes nothing
  5. #5
    Everything I do, remove battery, press power and volume buttons, phone always come up to recovery, then manual mode,
  6. #6
    oh no! I have the same problem! Did you ever find a solution?
  1. 'enter' or 'return' key on Google keyboard in hangouts?
    By GoBigRed4 in forum Motorola Droid MAXX
    Last Post: 11-01-2016, 01:04 PM
  2. Downgrade to Android 4.1.2
    Last Post: 07-29-2014, 03:38 PM
  3. Why is it taking so long for Vodafone to upgrade my software.
    By Maureen Anderson1 in forum Vodafone HTC One
    Last Post: 06-21-2014, 11:53 PM
  4. Gone from iphone to s5 help needed
    By tony5496 in forum Samsung Galaxy S5
    Last Post: 06-19-2014, 10:53 AM
  5. Export android wireless settings to XML?
    By nyrangers1994 in forum Android 4.4 KitKat
    Last Post: 06-19-2014, 10:28 AM
