1. AC Question's Avatar
    First off I am new to android. I have had an S5 for about 2 weeks now.
    My Wifi was working fine at work. For some reason it is not working any more. It works fine everywhere else. I have double checked the password and everything is good that way.
    In the Wifi settings it keeps saying "obtaining IP address...". Then I get a message that says "network disabled because internet connection is slow".
    I am not sure what the problem is. All of my other devices are connected and operate great.
    Any one got this?
    06-20-2014 10:35 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Go to Settings>Wifi, tap the Menu button, then Advanced, and see if there is an option to "Avoid Poor Connections" and uncheck it. Also, if there is a "Wifi Optimization" option, turn that off as well, because that is usually to try saving battery, not to improve reception.
    06-21-2014 03:02 AM
  3. Flyer1-Pre's Avatar
    I'm running a Samsung Galaxy 5. Had it about a month. While away, it kept dropping wifi, I thought it was the hotel. Now that I'm home, it's still dropping. The only way to turn it on is to restart. The settings-wifi-on switch just doesn't move.
    I can't find the menu options you refer to. Thanks.
    06-22-2014 09:01 AM
  1. nexus 4 rooted internet problems
    Last Post: 06-21-2014, 10:55 AM
  2. about wifi password
    Last Post: 06-20-2014, 10:26 AM
  3. Phone Battery Problem?
    By TheOriginalCJM in forum Ask a Question
    Last Post: 06-20-2014, 09:29 AM
  4. Android Launcher Problem
    Last Post: 06-20-2014, 09:24 AM
  5. Ringtone Change Problem In MOTO E
    Last Post: 06-20-2014, 01:18 AM
