1. AC Question's Avatar
    I have got Sony xperia M2 Dual last week....
    I have inserted a 8 GB SDHC card now...
    I want to increase its capacity to the phone's highest ability to read a memory card (i.e.,32 GB is the maximum capacity of Sony xperia M2 above which it cant read.. for example a 64 GB SDXC card cant be inserted in it)...
    My friend says that it will make the phone lag.....
    Please clarify my doubt on this , if it will lag then I will go for a 16 GB one...
    It is my first question in websites. If I have anything wrongly or without any clear details notify me so that I could correct myself...
    Thanks in advance...
    06-21-2014 09:38 AM
  2. frag06's Avatar
    Lag has nothing to do with capacity. If you're going to fill the 8GB card to capacity, though, you should definitely go for a 16GB card.
    Lag generally has to do with read and write speeds when it comes to SD cards. It shouldn't exactly make your phone lag, but if your card has a slow read or write speed, and you are trying to access an app on the SD card, it could take a little longer to open than if it were on the internal memory.
    It shouldn't make your entire phone lag.
    If you have any more questions, we are here to help!
    DineshHsenid likes this.
    06-21-2014 09:48 AM
  3. DineshHsenid's Avatar
    Thank you for this very fast reply... Havn't expected it....
    So I could go for a 32 GB SDHC in my M2 Dual right ?
    06-21-2014 10:09 AM
  4. frag06's Avatar
    If you need that much storage, then yes. Or if the price of the 32GB SD card isn't much higher than the 8GB or 16GB cards, you should definitely go for it.
    What SD card are you planning on buying?
    06-21-2014 10:19 AM
  5. Ayush Likhar1's Avatar
    I had the class 10 SDHC 16gb card in my yu yuphoria and it was working fine but when i changed it to 32gb class 10 SDHC card of same company (Strontium) .. the phone started lagging at every point ... i mean games were lagging (clash of clans , asphalt nitro) and UI became sluggish ... and as soon as i removed the card and tried the games , they worked smoothly . I am searching for solutions, can please anyone help , I want to keep the 32GB card in the phone not outside
    01-04-2016 12:37 AM
  1. Help nexus 7 stuck on the 4 bouncing ball animation !!!
    Last Post: 05-28-2016, 07:53 AM
  2. New system update for htc one won't let me unlock phone
    Last Post: 10-10-2014, 02:28 PM
  3. Razr not rooting, what the hell is going on?
    By CannedBullets in forum RAZR Rooting, ROM's, and Hacks
    Last Post: 06-24-2014, 02:25 PM
  4. Will the CDMA Galaxy S3 work on AT&T?
    By AC Question in forum Samsung Galaxy S3
    Last Post: 06-21-2014, 08:52 AM
