1. AC Question's Avatar
    Checked all controls. Did full system reboot after clearing cache. System recovers fine but No Sound whatsoever except with external jack and when I make a call. So incoming calls register but I cannot hear anything. Removed my SDmicro card as well. Did the battery removal and restart. Just ridiculous ... would appreciate a fix. KenW
    06-21-2014 02:22 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! I'm not entirely clear on what you're describing--so you can hear sounds using your headphone jack, right? But when you say incoming calls register but you cannot hear anything, are you saying that you hear the phone ring, but then nothing comes over the earpiece?
    Does the external speaker make any sound whatsoever? If not, I'd guess that the speaker or the related circuitry has failed.
    06-21-2014 06:41 PM
  3. Kenneth Wagner's Avatar
    Incoming calls register - no audio at all in either direction. I have not tried the headphones with calls but they work with youtube for instance... so essentially the built-in speakers are kaput ......
    06-22-2014 07:12 AM
  4. B. Diddy's Avatar
    How about trying a new SIM card?
    06-22-2014 10:28 AM
  1. video pauses again & again in samsung s5
    Last Post: 01-18-2017, 05:44 PM
  2. Samsung s5 s900h root
    By bbmjack in forum Samsung Galaxy S5 Rooting, ROMs & Hacks
    Last Post: 08-30-2014, 08:15 PM
  3. Replies: 1
    Last Post: 06-21-2014, 07:23 PM
  4. Can I choose which apps run automatically on my Galaxy S5?
    By thomasr1950 in forum Samsung Galaxy S5
    Last Post: 06-21-2014, 06:47 PM
  5. Verizon Moto X with Bad ESN on Straight Talk
    Last Post: 06-21-2014, 02:13 PM
