1. AC Question's Avatar
    There are quiet a few posting on the forum but I don't understand final verdict: So my questions are:
    Galaxy Tab 2 10.1 does not charge from wall outlet. Battery sign comes and tries to charge but dies and goes into loop
    I accidently tried to charge with Car charge in my car and it was charging.
    Came back home and tried to charge on the wall outlet, it did not charge : Message connect your charger.
    It is now somehow charging but with X sign on the battery.
    So is my battery bad or charger or tablet ? also for information, I don't use my tab quiet often so the battery is complete dead every 2-3 days and is not charged for atleast a week.
    06-21-2014 09:47 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Charging cables and charging plugs can fail, so you could test out a different one. How well did it charge using the car charger? Did the battery level actually go up?
    As you may know, it's not a good practice to let your device's battery die routinely. Modern devices won't let the battery drop to true zero, but if you habitually let it die, and then wait a while before charging, the battery might completely discharge, which is irreversible. If you know you're not going to use your device for a little while, power it down.
    06-21-2014 11:52 PM
  3. Johnly's Avatar
    Check your ports. Make sure they are tight. Otherwise it could be battery troubles if the cable and USB plugins are to spec.
    06-21-2014 11:53 PM
  1. How can emojis show up on a sprint samsung epic 4g
    By tiffypinky in forum Ask a Question
    Last Post: 08-26-2014, 09:00 PM
  2. touch screen and volume buttons not responding
    By georgia wrigley in forum Ask a Question
    Last Post: 06-24-2014, 03:08 AM
  3. Samsung galaxy s3 mini gtl8190 memory problem, pls help
    By nelly boy in forum Ask a Question
    Last Post: 06-23-2014, 03:07 PM
  4. Android Central App not working
    By Marcin Stachurski in forum General News & Discussion
    Last Post: 06-22-2014, 12:39 AM
  5. Kies now syns with Outlook YAHOO!
    By kway_NY in forum Samsung Galaxy Note 3
    Last Post: 06-21-2014, 08:17 PM
