Results 1 to 2 of 2
    Default Water damage help!
    I dropped my Samsung galaxy S3 in chroline water. I tried to turn it back on BEFORE it was completely dried, and it came on for bit, then glitched back off. After that I put it in rice for a day. Then I dried to alcohol method to get rid of the chroline trapped in it. Then it went in rice for another day. Now, when I turn it on the sounds work, it registers my touch and the led light works . But the screen remains black. Is there anything I can do?
  2. #2
    Default Re: Water damage help!
    Quote Originally Posted by Chanelle Mundy View Post
    By turning it on BEFORE it was completely dry you more than likely shorted it. There isn't much you can do. I know Radio Shack repair smartphones. You can take it there and see what they tell you. More than likely though your phone is permanently broke. Definitely take it to Radio Shack or look up a smartphone repair place and see what they tell you.
  1. Should I factory reset? help
    Last Post: 10-26-2014, 08:51 AM
  2. HELP! HTC One m8 Rebooting Every Minute!
    By jrsnively1 in forum HTC One M8 Rooting, ROMs, & Hacks
    Last Post: 08-17-2014, 11:23 AM
  3. "Spring Cleaning" gmail help
    By Artistlife in forum Google Nexus 7 Tablet (2013)
    Last Post: 06-26-2014, 12:08 AM
  4. Please help with .nomedia file viewing!
    By engwad in forum Ask a Question
    Last Post: 06-23-2014, 10:00 PM
  5. App Help
    Last Post: 06-23-2014, 06:05 PM
