1. AC Question's Avatar
    So, I followed this tutorial to root samsung galaxy note 3:
    In that video, when the guy roots the phone, after pressing start, the progress bar continues and says pass, but for me, instead of pass, I got failed message and the message appeared when a "disconnected USB sound" plays at the same time
    Then, I pressed & hold the power button, and received the message firmware upgrade encountered an issue. please select recovery mode in Kies & Try again
    And the USB connected sound plays
    Should I try rerooting?
    06-24-2014 07:33 AM
  2. Golfdriver97's Avatar
    Can the phone reboot?
    06-24-2014 09:02 AM
  3. Suresh Tailor's Avatar
    Hi,
    I have tried other Root methods on my Galaxy S3, but it failed badly. Then I found this ( All Android devices supported by Kingo Android Root) and Rooted my S3, Note 2 and Note 3 without fail. My friends and relations use this as well. Just open the website, choose the make and model, download the app and install it on your computer and you now have a Rooted device. Download Root Checker from the Play Store to check the Root Status.
    Running the Kingoapp after Rooting gives you an option to UnRoot the device as well.
    I hope you find this helpful.
    06-24-2014 03:14 PM
  1. Pairing Bluetooth in a Hyundai 2014 to a Galaxy S111
    Last Post: 08-26-2014, 09:08 PM
  2. Replies: 10
    Last Post: 06-30-2014, 11:08 AM
  3. Replies: 2
    Last Post: 06-24-2014, 01:57 PM
  4. Please Help.. SOS...... on my HTC m7... deleted os
    Last Post: 06-24-2014, 07:46 AM
  5. Replies: 1
    Last Post: 06-24-2014, 07:03 AM
