1. dustin_dej's Avatar
    I rooted my G2 (Verizon, running KitKat) I can see now SuperSU app. But it doesn't have any data. All it contains three Tabs 1:App(NoData) 2:Log(NoData) 3:Settings (have few options). What am I missing or haven't set up correctly?
    Thanks for any helpful advice!
    06-24-2014 12:26 PM
  2. mumfoau's Avatar
    I just rooted as well and noticed no apps in SuperSU....until I installed Root Explorer which needed to get permission from SuperSU. Now mine shows G2 Xposed and Framework Installer have SU access to my phone.
    06-24-2014 12:39 PM
  3. dustin_dej's Avatar
    Can you provide a link to it on the play store to make sure I'm getting the correct one? I searched for Root Explorer and it returned two results, Explorer by Speed Software and Root Browser by JRummy.
    06-24-2014 12:42 PM
  4. mumfoau's Avatar
    This LINK is the free version, "Explorer" the paid version that I have is the "Root Explorer"
    06-24-2014 12:48 PM
  5. dustin_dej's Avatar
    I went and grabbed ROM Toolbox and now everything seems to be working like I need it to. Thanks for your help though!
    06-25-2014 08:49 AM
  1. Replies: 54
    Last Post: 06-13-2016, 11:00 PM
  2. LG Optimus L7: Unlocking screen leads to dialpad!
    Last Post: 09-13-2014, 02:56 PM
  3. Help! Weather Clock Option Disappeared!
    By DividedShark in forum Samsung Gear 2 & Gear 2 Neo
    Last Post: 06-25-2014, 11:00 AM
  4. Newest tablet on gomroo? Any help would be appreciated.
    By eric_roberts in forum Samsung Galaxy Tab S 10.5
    Last Post: 06-24-2014, 01:32 PM
  5. Rooted VZW S5, now trying to disable Pattern Lock
    By BillyTRichVa in forum Samsung Galaxy S5 Rooting, ROMs & Hacks
    Last Post: 06-24-2014, 11:58 AM
