1. Katie Parker Banks's Avatar
    Hello. I dropped my phone in the toilet. The case was on, so water on the outside was minimal. Took the back off and wiped off what water I saw and all was good. Several hours later my phone went dim, everything looks significantly darker than what it was before. Everything still works on the phone except for the dimmer screen. Is there any way to fix this without getting a new phone? I just had my phone replaced a week ago due to a bad port and now this happens. Please help! Thanks in advance.
    Katie
    06-24-2014 07:04 PM
  2. Johnly's Avatar
    Try a screen adjust app in the play store. If the brightness is set to auto, and the sensor got wet, it may be registering as if it was in a dark room, hence the dim screen?
    06-24-2014 07:11 PM
  3. Katie Parker Banks's Avatar
    Thanks. I just tried a couple of them and it is only making my phone as bright as it will go as if I didn't even have the app. I think im doomed. Also, the screem almost has a slight dark bluish hue to it. I hope I don't have to replace it again. Thanks again.
    06-24-2014 07:27 PM
  4. Paul627g's Avatar
    Got could try putting it in some dry rice over night. Pull the backing and the battery and toss them all in and see if it draws out any remaining moisture. Might get lucky and it will work better tomorrow
    Sent from my HTCONE using AC Forums mobile app
    Johnly likes this.
    06-24-2014 10:07 PM
  1. Replies: 8
    Last Post: 06-27-2014, 07:42 AM
  2. Phone thinks I'm "docked" in a car
    By ChuloMan5 in forum Motorola Droid MAXX
    Last Post: 06-24-2014, 11:51 PM
  3. Replies: 6
    Last Post: 06-24-2014, 09:22 PM
  4. gmail and password lock after pattern lock
    Last Post: 06-24-2014, 07:04 PM
  5. Left in the dark with my Htc. Holiday problem
    Last Post: 06-24-2014, 04:02 PM
