+ Reply
Results 1 to 2 of 2
    AC Question
    AC Question's Avatar
    Guest
    Post Nexus 7 won't connect to WIFI and continue through start up
    Hi There, So I have had a few issues with this tablet. At first, the problem was that it was start on the google start up screen with the google logo. I was told to do the factory reset which I did. It worked perfectly as it started with no problem at all. Now the problem is that once I get to the screen where I select the wifi network I want to connect to, I get a message that says "Unfortunately settings have stopped". Once I click OK, I am brought back to the language screen and the whole problem starts over again... Would greatly appreciate any ways to maybe fix the issue, or get past the wifi selection screen.
  2. #2
    Default Re: Nexus 7 won't connect to WIFI and continue through start up
    Not sure if possible but can you opt to skip the wifi connection at the start up and get thru the start up wizard, then come back and setup your wifi.
    Sent from my HTCONE using AC Forums mobile app
  1. this tablet won't play movies!
    By jolie lovely in forum Google Nexus 7 Tablet (2013)
    Last Post: 06-28-2014, 08:11 PM
  2. HTC One X+ won't turn on!!
    By Amonaco23 in forum Ask a Question
    Last Post: 06-25-2014, 02:58 AM
  3. Galaxy note Pro and One Note
    Last Post: 06-25-2014, 12:56 AM
  4. Screen is turning on and off for no reason..
    By crx4me in forum Samsung Galaxy Note 3
    Last Post: 06-24-2014, 11:12 PM
  5. unable to browse internet with s4
    Last Post: 06-24-2014, 09:47 PM
