1. AC Question's Avatar
    My lock button was having some problems such as when I clicked it it wouldn't do anything or it would glitch and hold down, so I restarted my phone now nothing is happening, I can't get anything on the screen to work at all
    I've tried removing and replacing the battery and the SD card.
    I've tried holding Power + Vol Up + Home with no luck.
    I've tried plugging into power outlet as well as USB to PC, with no luck.
    No lights, black screen, no vibration.
    No previous battery issues.
    Anything else to try? Or do I need to make a trip to Verizon?
    06-25-2014 12:41 AM
  2. wizzrah's Avatar
    Hello!
    Are you sure the power button is not stuck? Was the phone rooted or modded in anyway?
    Sent from my AT&T One XL
    Spacebar Backspace likes this.
    06-25-2014 12:48 AM
  3. Spacebar Backspace's Avatar
    The phone is rooted, but it has been since the day I got it. I doubt it's the problem. would it still be covered under warranty? Lock button might be stuck as it was having issues, but now the phone doesn't boot
    --------------EDIT
    I just banged my lock button on my wrist really hard then it booted up, now I can't lock it because when I click the button it opens the power off menu. So how would I go about fixing my lock button?
    06-25-2014 12:59 AM
  4. wizzrah's Avatar
    --------------EDIT
    If you rooted the phone, you automatically voided the warranty. Does the menu come up immediately when you press the button?
    06-25-2014 01:25 PM
  5. Spacebar Backspace's Avatar
    The phone turns on now, it works perfectly fine no cracks/scratches. Now the button is just glitchy sometimes. It will sometimes hold down, sometimes work for a few hours, sometimes not do anything. That's why my phone wouldn't turn on
    ---- Edit
    Also according to "Magnuson-Moss Warranty Act title 50 of United States code chapter 50 section 2304 C waiver of standards" as long as the root didn't break my phone or they can't prove it then they have to give me a product. I just found that out today
    06-25-2014 01:44 PM
  1. Sprint Samsung Galaxy S5 Update
    By Devenchi in forum Samsung Galaxy S5
    Last Post: 07-10-2014, 09:08 PM
  2. Replies: 9
    Last Post: 07-08-2014, 05:11 PM
  3. Galaxy S5 typing issue...
    By Dabluebonnet in forum Ask a Question
    Last Post: 06-25-2014, 04:46 PM
  4. Galaxy S4
    Last Post: 06-25-2014, 12:42 AM
  5. Why no OS on my Galaxy s3?
    Last Post: 06-24-2014, 10:24 PM
