+ Reply
Results 1 to 2 of 2
    AC Question
    AC Question's Avatar
    Guest
    Default How to mount two USB devices via USB hub on OTG
    Dear friends,
    I have a small problem which I need you to help me.
    Is there any software which I can install on my android tablet so that via OTG cable connected to a USB hub I can copy an SDcard via a USB adaptor to an external hard disk.
    The problem I have is that only one USB device is mounted when I connect the setup listed above. Is there any file explorer app that can mount both USB devices connected to the USB hub.
    for your info, the tablet is rooted and use USB Stick mount app to try and mount both USB devices.
  2. #2
    Golfdriver97's Avatar
    Posts
    Global Posts
    32,673 Global Posts
    Carrier
    Pure Nexus/Franco Kernel
    Default Re: How to mount two USB devices via USB hub on OTG
    Have you tried ES File explorer?
  1. using s note to make appointment in note 3 google calendar
    Last Post: 09-12-2014, 11:57 PM
  2. Root Sanyo Cricket Zio How to?
    Last Post: 09-02-2014, 11:36 PM
  3. Replies: 1
    Last Post: 08-26-2014, 10:38 PM
  4. Unable to enable Amazon App Store
    By CannedBullets in forum HTC One M8
    Last Post: 06-27-2014, 03:50 PM
  5. Replies: 3
    Last Post: 06-25-2014, 11:20 AM
