A
AC Question
i bought a samsung tab2 p3100 on march 20th 2013.now the tab is showing charging issues and they told the problem is with the charging IC
,the motherboard and battery should be replaced which will cost me half the price of the tab.
now the samsung products quality is really annoying and the products are not worth the price u are paying. you wlll get the same configuration product of other companies and the price is also less when compared to samsung products.
